Extend srf
Hi forum, could extend srf be like extend crv, where you can extend as many surfaces needed before finishing the command .—-Mark
Currently, there is no way, but you can simply finish one surface and then “hit Spacebar or Right Mouse Click” to reactivate the last command.
Although this can be a welcome addition to the software, it is likely way down in the priority list, there are more important features that are needed for Rhino.
right click of the mouse will reactivate the tool.
I’ll write up your suggestion and get some feedback from the dev team. There may be a reason for the current behavior.
https://mcneel.myjetbrains.com/youtrack/issue/RH-69950/extend-srf
