If there are 2 curves /,, that would intersect at some point is there a command to ‘close’ them automatically instead of doing it manually with extend trim?
Similarly with Surfaces
Thank you!
Thank you!
Try the _Connect command…
There is also _ConnectSrf, but this is a bit more complex than connecting curves.
Right, sight thank you very much!
