I hope I will find an answer to my question. As I work with surfaces and solids I need to fill the gaps between two untouching surface as I described with images below. I need to extend edges to the other surface in perfect match. How can I do it?
Thanks for answer. Unfortunately extendsrf command fails to extend for some reason I really didn’t understand. ConnectSrf only provides edge to edge connection; however, in my case, I’m looking for edge to surface connection to imprint my extension on surfaces’ face. I don’t have any Idea on how could I use trim in this case but I will check the command once more.
If ExtrendSrf fails, you sometimes can make it work by first using _ReplaceEdge and/or _MergeAllEdges if there is a split in the edge you attempt to extend.
Note: Without posting geometry I’m only able to guess solutions, keep that in mind. Pictures often don’t give much info especially if a command fails. If _ExtendSrf fails then most likely ConnectSrf will too.
Writing from cell so can’t open your file at the moment, sorry.
Looking at your capture screens, I would give a try to put the construction plane to B and use the “align” commands to move the other plate’s edge on it.
I assume that the edge ona A is parallel to B to make align works correctly.
Edit: I opened the file, another way I would use is to ExtrudeCrv the bottom plate’s edge and join the extrusion to the plate.
After that a MergeAllCoplanarFaces would simplify the plate.
