I have the following problem and I don’t know if I’m in the right forum for it: D
I’m trying to export a project from Rhino and import it correctly into Keyshot, but the object never shows up properly. There is always a part missing.Error.txt (1.3 KB)
Hi @wadim2011
It would probably help with a little more detail: what Rhino version, what Keyshot version, how are you exporting/importing the file, what are you settings (in both Rhino and Keyshot) when exporting/importing? Or even better; post the file. Note that Keyshot still does not import Sub-D geometry. Also, unless you tick “Import NURBS” when importing the 3DM in Keyshot, geometry with no render mesh will not import.
HTH, Jakob
have you tried with the keyshot plugin in Rhino? you get it free from teir page
except for the sub-d geometry which needs to be converted to nurbs surfaces, everything goes well with the plugin:
