While exporting a a rhino file into DWG i have an issue with the texts / nomenclatures.
In rhino when oppening the rhino file, the texts are readable and on the good side, then if i export in DWG, everting is automatically inverted, texts are in reverse, unreadeable …
In Rhino, make sure to turn off the “Text reads forward when viewed from behind” option in the annotation style that you are using. This will then show you how things will be exported to DWG.
