How can one export to SketchUp in metric units?
Both my Rhino and SketchUp is set to metric, but Rhino insists on exporting to old imperial units. Since I don’t live in either Myanmar, Liberia or the US, I would really like to keep the model in the same system. Every time we have to update the system to metric, we lose the co-ordinates and of course some accuracy.
Is there a solution for this?
Tools…options…units…meters.
You can change the units there in Rhino.
Greetings
Hello - I see the problem, and I do not know the answer, I’ll ask the developer.
That does not change the Sketchup export at all. That is exactly the problem.
Exporting a metric Rhino file to SketchUp, always turns it into an imperial file.
did you choose the correct template? … metric / meters … imperial / inch …
Again:
i had sometimes this problem, but i think is a problem in “ketchup”.
“my Solution”:
1)-i open a file in rhino/ if you work with’ mts’ there-‘template mts’-…export
selection to sketchup file.ok.
2)-I open Sketchup, ( ‘’‘‘template meters’’‘’), but…the dimensions are in ‘’‘’‘inch’‘’'(?)…,ok…
… so you need open the windows-"info model "—and there
you can see ; ‘imperial system’ showed there…‘inch’.ok.
So first, click in “architectural” and change to "" decimal"" system
after that : dimensions : meters
volume : meters
area : meters
after that your template are in meters.
but first ( forever that) you need to save your " template"
and i think, you need to do that in windows-style-save new
with your name,so, everytime that you open SKP,you can open your personally template,for not to have this problem.
** i think that is a problem in sketchup,
i had the same when i work between these booths.
Greetings
No,that dont run,—template save— i cant find the solution.
Greetings
FWIW I don’t see this problem here at all…
I make a box 1200 x 1200 x 600mm in rhino, export it to skp format, open it in sketchup, and the tape reports the exact same measurements…
This is rhino 6 and sketchup 8 pro (which is the last version i will buy since I won’t use subscription software)
Perhaps the problem is with a later version of sketchup?
cheers
rabbit
When working with blocks, things get really bad!
Jumping onto this to also ask for this. My metric files are always turned into imperial during export. No problems with measurements changing, but have to manually re-convert each file then.
I am having the same problem. This is not really as it should be for a cad program. @wim, @pascal or someone else from mcneel, is it possible to come up with a solution for this problem.
Export metric and in Sketchup use import and not open…
Exporting in metric and importing does not help if the model contains blocks.
Block definitions become scaled as components.
Well if I import the file below which contains a block exported from Rhino as Sketchup file into Sketchup Make 2017, I can drag and drop it from the components tab and it has the right size.
block_cube_100x100x100.skp (8.0 KB)
