[Error /Bug Report] Rhino 6 exporting models to Sketchup format- Units issue
FIY, I’m not sure if someone tested this already but every time a model is exported into Sketchup format- the output (sketchup file) defaults into English system (Architectural/feet/inches), even when the Rhino file units has been set already to Metric. I hope they can fix this issue. Thanks!
Hello - I can’t tell if you think this is a Rhino problem or a SKP one - it looks like importing an skp file from Rhino into a metric skp file, works though.
Any movement on this? Quite annoying when working with others.
It is a Rhino problem. SketchUp simply opens the exported file.
A few years later, any input from McNeel?
