Hi, Im putting some labels in Rhino and then exporting to illustrator to make final arrangements but when doing so all my text gets formatted from á to á or ó to ó and arrowheads simply disappear… How can I solve this?
Thanks, Shynn
Thanks, Shynn
Someone any ideas?
Hi Shynn - is this on the same machine - that is, the font used is available to both applications?
Not sure, the font used is the default Rhino font.
Hi Shynn - Here, the file opens with a warning in AI that the text must be updated- I allow that and at least some of the special characters come on that I tried. But… Rhino’s AI export format is quite old…
Yup, I allow for update text too, but no luck still.
If it isn’t illustrator what do you recommend for creating this type of drawings Pascal? I make the model in Rhino and then section and make2Ds, but then I need to polish things, add colors, labels, dimensions, detail views, etc. I think AI is quite a solid option, I just have too many problems with Rhino exporting to AI… Hatches need to be exploded, text not being recognized, neither arrowheads…
Thanks
Shynn
Hi Shynn - what happens if you print to pdf as vector? Does that do anything good with the text?
Hmmm, yea much better. I guess I could export to pdf and tweak that pdf in AI. Thanks
