Export STL Option (Tolerance) in command line
I export a mesh in STL format like:
-_Export “file” _Enter “path” _EnterEnd
wonder how to set the option like tolerance in the command line
Thank you so much
Hello - run through it once ‘by hand’ using the Browse option - set an STL file name - then you’ll see the subsequent prompts for the various settings.
Thanks for the reply.
I did but I don’t see the Tolerance option =(…
also, I wonder how to add the options to a command line
Hello - the Tolerance in stl export is the ‘Maximum distance edge to surface’ setting in the meshing controls.
thanks for the suggestion. What is the syntax of that btw?
