Export selected
when i export to stl, i have 2 cylinders that come out as a hex.
If i export as a stp file and import to different software is comes round.
these are the 2 settings and both had same result.,
any suggestions how to export to a stl as cylinders?
Hello- STL is a mesh format, when you expiort, you get to set the mesh partameters for converting surfaces (exact) to meshes (approximate) - the mesh can be ‘smoother’ - that is, more facets more closely approximating a cylinder but it will still be a mesh - see
https://wiki.mcneel.com/rhino/meshfaq
Thanks!@
I exported as an obj then moved the slider to more polygons and it looks good now.
