I’ve tried to export a closed surface / mesh to STL but the file size remains at 0kb. These are about .5" by .5" by 5" tall column and should have a small file size (actual file size is about 188kb). However, putting this into my 3d printer or other repair softwares results in an error message.
Unfortunately the only type of input my 3d printer takes is an STL, so I’m assessing how best to export to be readable by other software other than itself.
If the export is 0 Kb, nothing is getting exported. Is the object being exported valid? Do a SelBadObjects to see. Rhino will not export invalid (bad) objects.
If it’s valid and not exporting, please post the Rhino file with the object here along with your STL export settings.
Here’s the file in question. It’s not just this one file. Essentially all my Rhino 5 programs have all been exporting with 0kb. thanks for looking into this.
I have three machines running Rhino 5 that I tested on. Two personal, one corporate. It seems all file types that do mesh export: obj, vrml, etc. are creating problems as well.
You have the latest service release of V5?
What version of Windows? Updated recently?
Are these problems recent? Did they start with an update of some kind?
Does this happen with absolutely all files, even a simple box?
Do you have a Rhino file you can post here that doesn’t work on your end?
I have the latest build of windows with updates just a few days ago
I have the latest up to date Rhino service release as well.
These problems are recent, with latest update to Windows 10. It’s happening even with a simple box as well, registering 0kb.
Hmm, very odd that it should be happening on 3 different machines. The STL export seems to work OK here in V5 or V6 (I’m on Windows 8.1 though). I don’t have any explanations for the moment. What are your STL export settings? If you use _Mesh to mesh the object first, then export the mesh object, does it work any better?
