Hello, I wrote a simple script to bring back the Rhino Make2D layer hierarchy to exported Illustrator file.
Simply open the exported Illustrator file, then run the script.
I tested this in Illustrator CC 2019, but it should work in newer versions as well. You can find the “fix_layers.jsx” script on my GitHub
This is what the script does:
I hope this helps some of you.
