Hey there,
I’m currently working on a script which does a intersection of a surface with other surfaces that are stored on a layer(Surfaces4intersection). The surfaces from the layer will have custom names. The script will return a curve resulted from the intersection of my surface with the surfaces from the layer,and the curve will be saved on another layer(Line_from_intersion). The line will have the name of the surface from the layer Surface4intersection. Then I export the line to AutoCAD and I when do that, the line in autocad keeps its layer name,and its color,but not its name.
Do you have any ideas how I could export the line to keep its name, and also, in autocad, to create a property of the line to store the name,because now it does not have one.
Thanks
