Trying to make a series of jpegs for a parts library and diagram instructions. All individual objects are at varying scales but I need a consistent line thickness regardless of the scale when I export. I have messed with settings in the print dialog with no success. Is there a way to achieve this? I have also tried generating 2d drawings from the models and models themselves in pen display with no success. Models in pen display is preferred.
Hi Dani,
Can you post a small example file of your setup?
Attached. Thank you.
line drawing_test.3dm (5.7 MB)
I’ve been using the Print command, selecting jpg and attempting to toggle and mess with the settings.
But does this impact the print export? In changing pixels vs object width there was no change when I went to print and compared the two. Theres a change in printing the pen view of the model vs the line drawing.
sorry just so I’m clear - there would need to be different output and dpi adjustments depending on the size of the object to get consistent looking lines?
