I am trying to simplify ways of producing plan drawings and technical drawings for clients at work instead of relying on the limited options of Make2d. I have stumbled upon this weird bug after exporting a layout detail to PDF:
This is a screenshot from the layout detail with the Pen Displaymode
I have set the line thickness in display options to 1px and it is clearly more than one pixel thick in the pdf. Is it possible to have rhino export lines as one pixel no matter what DPI you export it? It seems like it scales the lines - it is still pretty high definition, but the lines are just way too thick.
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 2-1-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.69
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-1-2022
Driver Version: 30.0.15.1169
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
The only way to get an image into the PDF file that looks like what you see in the viewport is to take a screengrab of the viewport and put that on the layout.
To have the PDF output correspond with the viewport or print preview is a feature request that is on the list as RH-46318 but that will take a completely different way of doing things.
