Export doesnt work in Rhinoceros 3
Hello, ive been moddeling for a game thats called Arma 3, im trying to export it but when i click export i can only chose Rhino 3 and Rhino 2 files, im currently using Rhinoceros 3
Hi Victor - sounds like plug-ins are not loading. I do not have V3 installed at the moment… I can’t remember off hand, does V3 have the PlugInManager command? if so, try to load plugins from that. I’ll see if I can get V3 loaded up here and maybe be of more help. You might also set V3 to run in Windows ‘compatibility mode’ for XP, assuming you are running a later version of Windows, and for good measure start it with ‘Run as Administrator’
Thank you it seems to work now thanks for the help :smiley:
