since fews days,
export selected objetcs function isn’t working anymore.
Rhino bugs when I use it and nothing more is possible to do with. Only restarting.
Do you thing it’s possible to repair it ?
I restore system on a four month before date but nothing change.
Hi Philippe - what happens exactly, please? You select objects and start Export and then what? Can you export if you start Rhino in Safe mode? What service release of Rhino are you running (Help menu > About Rhinoceros)?
SafeMode starts Rhino without using accelerated graphics and without loading plug-ins.
On the Windows Start Menu, click the item Rhinoceros 5.0 in Safe Mode or Rhinoceros 5.0 (64-bit) in Safe Mode, or type ‘Rhinoceros’ and look for the Safe Mode entry.
as I write, when I use in menu “export selected objects”, Rhino doesn’t
answer anymore. My SR is 12th.
When I run Rhino5 64b in Safe Mode, it’s working right.
Last module I’ve download on Food4Rhino is Rhinosli3r.
When I desactivated it, “export” works again.
