have 45mm square item, export as .ai
open in pshop CS6
says 82.2 x 45.16 72dpi.
whats going on ? SR6 arch supports Rhino8.ai (1.5 MB)
How do I get this into Pshop as thin white lines to overlay over a scan of a print of it ?
firstly it opened square with thick lines, when it was on a layer line thickness default, , I then made lines 0.001mm then get this happen.
To open an SVG file as a rasterized layer, go to File > Open and select your SVG file. Alternatively, you can open an SVG as a vector by creating a new document, going to File > Place Embedded or Place Linked, and selecting the desired SVG file
