Selected first pink objects and did File> export selected as Adobe Illustrator, cmyk and 1ich = 1inch.
repeated then for orange.
Open the pink ai into pshop
I get pink suggestion by pshop of 334.639inch wide and 273.75 height 72dpi, as original is 334.6339 inch wide and 273.7289 inch height I go with that.
I then open the orange item, and get 353.403 inch width and 128.681 height when original is 71.8115 width and 39.4063 inch height,
I draw a blue rectangle same size as the orange and still get that crazy size.
So I then alter width in the opening dialog box to our 71.8115 but that makes the height 21.49 so in fact its not even proportional, WHATS GOING ON ???
I am simply trying to overcome the failing of Rhino to have a distort tool by doing this distort in Photoshop.
Is Rhino unable to export ai proportional and same size as the objects selected ?
Can someone export the pink then the orange items as ai, keeping inch = inch.
open the ai of the pink into pshop, then open the orange.
What do you get ?
How can I get these into photoshop same size and proportional ? ai should work !
Furthermore if I make the opening height of orange 39.4063 thinking I will scale the width to the 71.8115 after its open, as these are all 72dpi files, how become when I copy paste the orange into the pink its only a third of the height of the place it came from in Rhino ? even more crazy.
Export ai sees pshop crazy dimension.3dm (6.7 MB)
Steve
