Hi all, is there a simple way to create a exploded view wich shows all parts of my object exploded?
And can i add labels with a partnumber ? When i select a part and look at properties i see that i can give a name to this part in properties, is it possible to get this name vissible in my drawing like a label?
Hoi Bart -
The short answer to that question would be “no”.
You’ll have to do this manually by moving objects and, if required, create the dashed lines that often go with that type of illustrations. You would start with the current position and save NamedPositions (or a SnapShot if you also have a layer for those dashed lines) for all of your objects. Then move, and save a new NamedPosition.
Yes, you’d use the ObjectName text field for such:
