Hi everybody!
I am currently working on the optimization of a building envelope (through a software called ModeFrontier linked to the Grasshopper file I am working on), through energy simulation and daylight anaylisis with Grasshopper.
When the simulation is run on grasshopper, a window-message pop up on the screen, not allowing to finish the simulation. This message is the following:
Component Exception:
Honeybee_Read EP Result
An exceprion was thrown during a solution:
Component: Honeybee_Read EP result
c_UUID: c46d850f-efb8-4074-906e-f9ece818e3bf
c_POS:
A second message appears when clicking on ‘‘OK’’.
With some research, i understood that this problem is linked to the version of the plugin IronPyhton, but even if install the latest version the problem continue to occur.
Can someone help me, in figuring out what do i do wrong?
Thank you in advance,
Best regards
Fatima
