Basically everything is offset so I can’t even make anything cuz it won’t connect properly, I don’t know why or how this happened, but now I cant draw anything correctly or connect/place my objects where i want to. When i press the render view, the line and the actual object don’t even match up so when i do try to create something and place it along the curves, it doesn’t connect to the mass right. I hope i worded this correctly because I don’t even know if I’m describing the problem correctly.
Pro-tip: press windowslogo+shift+S, you’ll be able to select part of your screen as screenshot, no need to use phone or table to take pictures.
Anyway, this looks like typical Far From Origin problem.
Hello - are your objects very far from the world origin?
