Hello folks, this is my first post here. Fairly new to rhino. Basically I’m trying to build a sign and I’m trying to make sure that the pieces I cut fit together. The black outside line defines the outer edge of the shapes, and the green is an attempt to trace that black line with a .25 offset. I want it to stay true to the curve though, as if a .25 bit would be cutting an offset path. I tried fileting the corners but it isn’t working. Any suggestions would be much appreciated. Thanks and thanks!
uploading the file hereIMAGINE-offset-problems2.3dm (9.2 MB)
