I use Solid Difference to obtain the difference between two sets of Brep then I want to use Evaluate Surface and MD Slider to move points along the resulting surface. As I understand, if I use Evaluate Surface directly on the Solid Difference, one of the initial surfaces will be evaluated.
However, when I try to create new surfaces with Deconstruct Brep and Boundary Surface, the Evaluate Surface seems to be unable to move the point regardless of what I do in the MD Slider. Here, the point is not moving and keeps sticking to one corner of the surface.
Thanks for your reply. Indeed you solve the problem.
However now that I can manage the point with MD Slider, only half of the result has the desired result, and the other half is somehow inverted.
Here’s a possible quickie assuming your surfaces are always planar rectangles with their Z direction(s) parallel to the Rhino plane Z vector:: srfdirection.gh (11.9 KB)
Use your boundary surfaces instead.
