When I try to use the Solid Difference command, not all Breps are substracted.
Übung 1 Geometrie und Parameter.gh (51.5 KB)
This looks like the same thing addressed a week ago? DUPLICATE THREAD!!
This is a massively complex bit of code, considering the result - which is difficult to see unless you use the “Only draw preview geometry for selected objects” feature:
[missing]
Are you aware of this?
[box_2024Apr2a2]
Which does not give you what I presume you want? This is more like it, eh? The result of flattening the input to Solid Union?
[box_2024Apr2a3]
As for the eight spheres, instead of complex rotations you can use the eight vertices of the box and create them all at once. …
No, it isnt the same thing, its a different problem. My problem now is that solid difference isnt working.
Piotr
April 8, 2024, 1:22pm
4
Skip first boolean ond focus on the other:
Could you send me the file please?
Piotr
April 8, 2024, 1:35pm
6
This is your very own file
Load all your creation into B and flatten the input. Nothing else.
You don’t understand it.
Did that last week but it apparently didn’t help.
Thank you very much, it worked!
Next time I’ll make sure not to create a duplicate thread, sorry for that. Also apologies for maybe not seeing the obvious, first time using grasshopper.
It appears that you have three duplicate spheres (“Untrimmed Surface”) :
It’s very important to know what your data trees contain, and their structure, coming out of and going into components.
