I am trying to draw a geometry within the boundaries of a surface. The geometry within the boundaries is dependent on a graph.
It works for the red planar surface. If I now try the same with the purple surface, which is not planar, it doesn’t seem to work anymore. I don’t know if the error might be in the construct point.
You are supplying uv coordinates to the Evaluate Surface component that are outside the uv space of your surface (surface u domain is 0 to 1 you’re feeding values in range 0 to 138.43175)
