hello,
is there a way where i can evaluate 2 surfaces , breps or more while they are distanced and cant be joined together as one ?
attached a pic to describe
img1: the 3 surfaces are acting as a 3 different surfaces,
img2 : looking at the 3 surfaces to act as 1 , where the evaluation of the 100% goes according to all the surfaces together , where the point just between the 3 surfaces
i dont have anything special evaluate surface.gh (7.9 KB)
im trying evaluate the combined effect of multiple separate surfaces or B-reps as if they were one continuous surface, without joining them together , they can be unjoined or distanced from 1 another
this is the file i got for now , i havent been able to figure out how.
when you say “evaluate a surface”, what kind of values do you expect to get?
for instance, would you expect the md-slider to sample just one point in total, instead of one point for each surface? what happens if the point to be evaluated falls outside of one or more surfaces?
I expect the multi-dimensional (MD) slider to treat the three surfaces as one connected surface. For instance, if I specify coordinates like (0,0), it should refer to the top-left corner of the small left surface. However, if I specify coordinates like (1,1), it should refer to the bottom-right corner of the right-side surface. Essentially, I want the slider to visualize all three surfaces as if they are a single continuous surface, rather than treating each surface separately.
the best I could think is something like this, where the horizontal [0,1] domain is proportionally split in 3 parts (3 surfaces), while the vertical domain is always [0,1]
