Hi there @mathieu1 @shapediver @snabela ,
I have some problems loading the plugin in Mac OS (Sonoma 14.4.1 (23E224) on M3 Pro); everytime grasshopper loads it opens a window popup giving me these errors:
I am attaching the text version here below.
Errors.txt (103.1 KB)
Also, after closing the above window this other popup comes up with this info:
An exception happened when adding menu items:
Castle.MicroKernel.ComponentActivator.ComponentActivatorException: ComponentActivator: could not instantiate ShapeDiver.SDK.ShapeDiverSDK
—> System.Exception: Could not instantiate ShapeDiver.SDK.ShapeDiverSDK.
—> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
—> Castle.MicroKernel.ComponentActivator.ComponentActivatorException: ComponentActivator: could not instantiate ShapeDiver.SDK.Util.SdkEnvironmentJsonConfigSingleton
—> System.Exception: Could not instantiate ShapeDiver.SDK.Util.SdkEnvironmentJsonConfigSingleton.
—> System.IO.IOException: Read-only file system : ‘/shapediver’
at System.IO.FileSystem.CreateDirectory(String fullPath, UnixFileMode unixCreateMode)
at System.IO.Directory.CreateDirectory(String path)
at ShapeDiver.SDK.Util.SdkEnvironmentJsonConfigSingleton…ctor(String pathToJSONFile)
at InvokeStub_SdkEnvironmentJsonConfigSingleton…ctor(Object, Object, IntPtr*)
at System.Reflection.ConstructorInvoker.Invoke(Object obj, IntPtr* args, BindingFlags invokeAttr)
— End of inner exception stack trace —
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture)
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object args, CultureInfo culture)
at Castle.Core.Internal.ReflectionUtil.Instantiate[TBase](Type subtypeofTBase, Object ctorArgs)
at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateInstanceCore(ConstructorCandidate constructor, Object arguments, Type implType)
at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateInstance(CreationContext context, ConstructorCandidate constructor, Object arguments)
at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.InternalCreate(CreationContext context)
at Castle.MicroKernel.ComponentActivator.AbstractComponentActivator.Create(CreationContext context, Burden burden)
at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.CreateInstance(CreationContext context, Boolean trackedExternally)
at Castle.MicroKernel.Lifestyle.SingletonLifestyleManager.Resolve(CreationContext context, IReleasePolicy releasePolicy)
at Castle.MicroKernel.Handlers.DefaultHandler.ResolveCore(CreationContext context, Boolean requiresDecommission, Boolean instanceRequired, Burden& burden)
at Castle.MicroKernel.Handlers.DefaultHandler.Resolve(CreationContext context, Boolean instanceRequired)
at Castle.MicroKernel.DefaultKernel.ResolveComponent(IHandler handler, Type service, Arguments additionalArguments, IReleasePolicy policy, Boolean ignoreParentContext)
at Castle.Windsor.WindsorContainer.ResolveT
at ShapeDiver.Common.Container.IocContainerSingleton.ResolveT
at ShapeDiver.SDK.ShapeDiverSDK…ctor(IIocContainer iocContainer, String clientId)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.Resolve(CreationContext context, IReleasePolicy releasePolicy)
at Castle.Windsor.WindsorContainerExtensions.Resolve[T](IWindsorContainer container, IEnumerable1 arguments) at ShapeDiver.Common.Container.IocContainerSingleton.Resolve[T](IEnumerable
1 arguments)
at ShapeDiverForGrasshopper.SdForGhIocContainer.get_ShapeDiverSDK()
at ShapeDiverForGrasshopper.ShapeDiverTopLevelMenuCreator.b__1_0()
Please let me know if you have a solution on how to solve this or if it takes more time to investigate.
Thank you in advance for your support!
