Error loading RhinoCycles plugin
This problem started popping up for when starting Rhino 8 SR 4:
Error occurred loading plug-in
 Details:
The process cannot access the file 'C:\Users\worker_user\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\RhinoCycles (9bc28e9e-7a6c-4b8f-a0c6-3d05e02d1b97)\data\RhinoCycles20240215431003.log' because it is being used by another process.
mscorlib
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.InternalDelete(String path, Boolean checkHost)
   at RhinoCyclesCore.Core.RcCore.PurgeOldLogs()
   at RhinoCycles.Plugin.OnLoad(String& errorMessage)
   at Rhino.PlugIns.PlugIn.InternalOnLoad(Int32 pluginSerialNumber)
This is fixed in Rhino 8src5. This happens when you start multiple Rhino instances at the same time.
@nathanletwory
I’ve just had the same issues popping up with 8.5 on windows
Systeminfo:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9181.0
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 11-18-2018 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M2000M (NVidia) Memory: 4GB, Driver date: 11-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-2-2023
Driver Version: 31.0.15.3779
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
Hmm, I will need steps to reproduce - Each log file is opened with a process id of the running Rhino. I have not seen two Rhino instances being run with the same process ID. That is something that is globally unique to the machine being run on, determined by the operating system.
I just opened a file and that error popped up. Haven’t had it happen before yet.
Right, my point is that for that to happen Windows should start two Rhino instances with the same process id.
Well, I’ll try to go over the code and see if there is something I missed.
Logged RH-81208 Log file access problem while starting Rhino
A collueague of mine has the same issue. I could ask for log files if that’s useful?
You need to make sure you’re on Rhino 8.6
Sorry @nathanletwory. Just had this pop up again.
(8.6.24101.5001, 2024-04-10)
Hmm, the date of the file is 16th of April, 2024. Does this mean you have still an instance running that you started back then?
Yes…
Ok, then I have another location I need to protect, and I know where to make a fix for this. Thank you for the information, that was a crucial bit I missed.
edit: I have a fix ready, I’ll link you to a fresh build when one is ready (probably tomorrow)
RH-81630 RhinoCycles fails to load when trying to clean up logs
RH-81630 is fixed in Rhino 8 Service Release 7 Release Candidate
RH-81630 is fixed in Rhino 8 Service Release 7 :building_construction:
