When Ask to load disabled plug-ins is checked, and Rhino is restarted, if window asking the user to load the plug-in gets lost due to the user having multiple windows open, the window does not show up on the list of running applications by using ALT-TAB, however it does show up when using WIN-TAB.
Windows Main Display is laptop’s integrated screen or built-in port
Primary OpenGL: NVIDIA RTX A2000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 1-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.18
Integrated accelerated graphics device with 4 adapter port(s)
Secondary monitor is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-2-2024
Driver Version: 31.0.15.3818
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\Mike\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\CodeListener (8c4235b6-64bc-4508-9166-bef8aa151085)\0.1.7.0\Rhino 5.0\x64\CodeListener.rhp “CodeListener” 0.1.7.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
Hi @Mike24 sorry but I still have no clue why that wouldn’t work on your system.
If you start Rhino and wait, does it show the dialog on top? Or maybe you can make a screen recording of how you are doing it so that we can try to reproduce?
@Gijs - Ya it shows it on top. But if you switch to a different application then it’s very difficult to get back to the window. I uploaded a video (screen recording). See the link below. Alt-Tab does not work as show at 0:00:11 - 0:00:17, 0:00:27, 0:00:35. Notice also that there is no active Rhino icon on the taskbar. Win-Tab does display the window for the user to change to it as shown in the video at 0:00:20 and 0:00:39.
So the following changes should be made regarding this subject when the disabled plugin window is initialized:
The window should be included when switching applications using Alt-Tab, not just Win-Tab.
The Rhino icon should be active on the taskbar so the user can use the mouse to select Rhino, therefore making the disabled plugin window active.
I’m glad we can still access the window by using Win-Tab.
@Gijs - The way I ran into this issue is I had started Rhino and got a call. I had to immediately lookup an email so I switched to that application and could not get back to Rhino via Alt-Tab or clicking on Rhino on the taskbar. Fortunately, Win-Tab worked. It should work via all 3 methods.
@Gijs - Ok weird. I do have 7+ Taskbar Tweaker installed which manipulates how Windows works. I was going to stop 7+TT and test this issue again since it’s only happening on my machine. I updated Rhino this morning to Version 8 SR7; (8.7.24113.23001, 2024-04-22) and all of a sudden Rhino is not asking me at all about disabled plugins on startup so something changed between SR6 and SR7. Once this is fixed, I will test this again. Can you test on your machine to make sure it’s not asking at all about disabled plugins with SR7?
