Anyone else getting error messages like this when opening a file?
The file will open, but then Cycles is unavailable.
I am confused by this - The log file that is being created should be unique for the process.
I am currently not able to try reproduce this, but as soon as my Windows machine is working I’ll investigate more closely.
Logged as RH-81208 Log file access problem while starting Rhino
It’s intermittent for me as well. Happened last week once, then started happening today again. I also have an instance of Rhino 7 open, I wonder if that’s part of the problem.
Rhino 7 does not have the logging that appears to be the problem in Rhino 8.
I have to figure out how two processes end up with the same process id to use.
Yep, I get this too. Without using R7, but when using multiple instances of R8.
VRay is selected as renderer.
Typically goes away after a SR update… then seems to return.
FYI, I haven’t had the error pop up again since reporting here. But I also haven’t downloaded that latest version just suggested @nathanletwory .
Let me know whenever you have managed to test the newer version. That’d be great.
