Hi ShapeDiver Team,
I have noticed an error in the Drawing-Function in connection with the parameter validation. If I start the Drawing-Function, change another parameter, and then accept all parameters, the Drawing-Function does not terminate. As a result, I am unable to start another Drawing-Function.
Additionally, I cannot manually stop the initial Drawing-Function to resolve the issue and have to reload the page.
The same issue occurred in my original file when I first accepted the Drawing-Function but then switched to a different Drawing-Function in the same step. In the example file, this would mean changing “Point Input A,” accepting only the Drawing function, switching “Choose Input” to “Points B,” and then accepting everything. However, in my test (ShapeDiver App Builder), I was only able to reproduce the issue once, which makes me suspect that the file is not complex enough.
I assume the problem might be related to loading times and the sequence in which processes are completed, but this is just a guess and might not be accurate.
Best regards,
Finn
