I cannot understand why I get the unconnected node error. While everything is flattened and the supports and loads are on the mesh points.
Solution exception:There are 6 unconnected nodes in the model:
node-ind:3531: (18.9832744598389/18.2733154296875/0.0125000001862645)
node-ind:4358: (18.9082736968994/18.2733154296875/0.0468747280538082)
node-ind:4704: (18.9282741546631/18.2733154296875/0.0468747280538082)
node-ind:5050: (18.9482746124268/18.2733154296875/0.0468747280538082)
node-ind:5390: (18.9832744598389/18.2733154296875/0.0375000014901161)
node-ind:5396: (18.9682731628418/18.2733154296875/0.0468747280538082)
keuj.84
(Keuj.84)
June 8, 2020, 3:34pm
2
hello @n.sidiropoulou
Can you share your definition ?
keuj.84
(Keuj.84)
June 8, 2020, 6:03pm
4
it’s not working, you cannot internalize your data ?
Sorry, try this link. The data are internalized thatswhy the gh file is big.
Shared with Dropbox
keuj.84
(Keuj.84)
June 9, 2020, 9:05am
6
It’s look like a numerical precision problem.
I can’t help you, but maybe with Karamba there are restrictions for a very small model like yours.
You have point coordinates with 13 digits after the decimal point
As attached, I internalize your structure with an x100 scale, and everything seems to be working.
You should see this problem with Karamba support @karamba3d
structural script JP.gh (878.1 KB)
I solved the problem by setting 0.001 to the LDist(limit distance for coincidence points) of the mesh shell components and the assemble one. Thanks!
