Problem with support and assemble in karamba
I,m trying to have an algorithm with karamba plugin. when i connect the support to assemble karamba, an error occurs. the massage is this: (solution exception: Could not find node at (…) where support number o is attached). how can I correct this?
Reza
hi @heavenly_diana2000
Try to flatten your elements in the assembly model component, I always flatten each parameter that was connected to the assembly components to be sure to have only one model (a list)
You can use remove duplicate points component,or cull duplicate component. Sometimes there duplicate supports points in the definition.
Can you share your definition if that doesn’t work.
Regards
Thank u so much, it works.
