Hi everyone,
I’m unable to import an IFC file in Rhino 7, while the same file opens without any errors in Rhino 6 (image below).
The IFC importer in plugin manager is loaded and enabled.
Any clues?
Thanks in advance!
Hi everyone,
Any clues?
Thanks in advance!
Hi @RdK
You should probably move this to the VisualArq category, if it’s their importer you are using.
-Jakob
Done! Thanks
Hi @RdK,
Before trying to import an IFC file, make sure VisualARQ is loaded. Just run any VisualARQ command like vaInit or create a new document using a VisualARQ template, and then try to import the IFC file again.
Regards,
Enric
Hi @enric,
I was under the impression that Rhino was able to import IFC files without using any extension - hence the question.
Thanks for the clarification!
Regards,
Rui
