Internalized the walls input so i could unpin, it looks like the cleanup condition on the wall is causing the issue. Check for overlaps on that corner.
I wonder why wall overlaps would prevent the group from being made?
I tried grouping the walls at that level manually in Revit and it works no problem.
I’m going to run into this issue a lot on different projects. Do you think there is any way to allow for the overlaps? Suppress the warnings somehow?
Or do you think it might be possible to detect the issue and trim back the wall or disallow joins from within grasshopper to prevent the issue? Sorry I know I’m grasping at this point.
Thanks so much for your help, it’s greatly appreciated.
No problem. I’ll dig into it some more & see if we can figure out what Revit is doing with those cleanups that won’t allow it into the group component.
