Erratic Display
My model started spontaneously displaying with a lot of errant lines (that dont exist). The display changes as I move in and out. its essentially a 2D drawing, but looks like its grown spikes!
Did I change a setting?
I’m also having trouble getting new objects to appear when I draw them.
What have I done?
Hi Kelly, this is a OpenGL artifact. Updating to the latest Rhino Mac should resolve this. If not please send us the file and reference this post. Rhino - Upload to Support
Can you type SystemInfo into the command line and paste the results here? Thanks.
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13002, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Educational Lab License, build 2022-07-27
Apple macOS Version 12.3.1 (Build 21E258) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro16,1
Language: en-US (MacOS default)
AMD Radeon Pro 5300M OpenGL Engine (OpenGL ver:4.1 ATI-4.8.15)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4080 MB
Graphics: AMD Radeon Pro 5300M
Displays: Color LCD (264dpi 2x), VX2703 SERIES (82dpi 1x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5300M (4 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
VX2703 SERIES (1920 x 1080 @ 60.00Hz)
USB devices
VIA Labs, Inc. : USB3.0 Hub
Kingsis Peripherals: Evoluent VerticalMouse 4
Realtek: BillBoard Device
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.21.22208.13002
Your macOS is a couple updates behind as well.
12.5.1 is current, and you’re on 12.3.1
I restarted my computer, and I am not seeing the errant lines now.
Thank you.
I’m not seeing anything (slightly different setup)
One thing you can try is switching the GPU Tessellation off/ reduce the anti-aliasing (less info going into the OpenGL pipeline). It located in Preferences>OpenGL
