Equivilant of Cinema 4D's Inner Extrude
A very simple question I’m sure but would appreciate any help with this!
In cinema 4D I can take a single polygon (surface) and use inner extrude to get the following shape in 1 step: https://ibb.co/zXrbptN
How do I do an equivalent move in Rhino?
Specifically, this is for building an inverted skirt around a wall.
Thanks so much,
Bebo
Hi Bebo - for a polygon, you can do this with Inset in the V7 WIP. To create surfaces you can do this in V6 with the Gumball:
  1. DupBorder your surface (or make say a rectangle as a curve)
  2. Select it.
  3. With Ctrl down, start dragging the Gumball plane icon in Top:
    to invoke 2d scaling.
  4. Press Shift at the same time to convert 2d scaling into extruding
However there is not a way to quickly ‘subdivide’ a V6 surface in the way that you describe. V7 will have sub-division surfaces, these are partially implemented in the V7 WIP builds.
Great - thanks so much for your quick response Pascal.
The gumball works well - is there a way to scale to a set distance rather than just dragging?
I found the answer here: http://docs.mcneel.com/rhino/5/help/en-us/commands/gumball.htm
Thanks again!
In fact - this only works on a square - what if I need an inner offset of a regular distance on a rectangle? Scale won’t work in this instance.
Cheers
Hello - then you’ll need Offset, followed by Loft.
Ah yes great, thanks Pascal
