archz2
March 2, 2021, 7:18am
1
I’m trying to extrude a portion of a hexagonal prism so that it looks like this.
Unfortunately, when I move the selected plane surface, undesirable morphing occurs.
hexagonal module.3dm (337.0 KB)
I made the desirable output by exporting the 3dm file to Sketchup and pushing the surfaces upwards.
How can I achieve the same in Rhino?
You can use direct editing on many Rhino geometries by holding control + shift and simultaneously clicking on a surface for example. Or select one surface after another, while holding control + shift
Use the gumball to scale with factor 0 to make it flat.
Use the gumball to move your geometry or parts of it to a certain height
Not sure if your bottom surface needs the division. You can get rid of it with the command MergeAllCoplanarFaces
If instead you just want a clean surface instead of the many isocurves, you can delete it and type cap
to build a fresh surface.
archz2
March 2, 2021, 8:17am
3
Moving the doodled faces while holding ctrl+shift gives warping. I want to have this type of geometry
archz2
March 2, 2021, 8:18am
4
martinsiegrist:
image1431×545 101 KB
Even in this photo warping is happening which is not required.
Select the 3 bottom faces and use ExtrudeSrf with the DeleteInput option set to Yes. Do not use the Gumball to do this.
Sorry I was giving you instructions on how to fix the warped surface
