I am trying to create this pattern on a torus and engrave it.
Im still new to rhino so sorry if this is obvious. I have made the pattern and the torus, now im not sure what the best method for this would be!
I have Rhino 7 - Mac
Sadly doesn’t exist
Mine doesnt exist.
This is my system info:
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19002, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Commercial, build 2021-05-07
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.2.3 (Build 20D91) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro16,2
Language: en-GB (MacOS default)
Intel(R) Iris™ Plus Graphics OpenGL Engine (OpenGL ver:4.1 INTEL-16.1.12)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Plus Graphics
Displays: Color LCD (256dpi 2x)
Graphics processors
Intel Iris Plus Graphics (1536 MB)
Color LCD (1440 x 900)
USB devices
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Users/moon/Library/Application Support/McNeel/Rhinoceros/packages/7.0/PanelingToolsScripts/0.2.2/PanelingToolsScripts.rhp “PanelingToolsScripts” 0.2.7432.20919
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.6.21127.19002
From your system info posted above:
Check the tabs in the grasshopper window, it should be there:
-Kevin
This is from the McNeel Wiki on PanelingTools from here:
https://wiki.mcneel.com/labs/panelingtools
This might explain why you aren’t seeing it. There is no menu in Rhino, you just need to use the command-line to run the commands.
on the Mac there is no toolbar for Paneling tools
simply type pt and the command search will show you the available paneling commands
HTH
Akash
Ah okay!
Well Now we have that sorted how would I go about doing this?
After watching a few tutorials I was able to make this:
Engraved_Pattern_On_Torus.gh (164.6 KB)
A bit slow and I’m sure it could be improved, but it’s my first attempt at making something with Paneling tools.
-Kevin
hi @kev.r
For a first experience using PT, that’s a pretty good result.
Well done.
Regards
Rodolfo Santos.
Strange, your system info shows that you have the Paneling Tools plugin:
My system info shows:
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.7.21145.1002
This is what I see when I run the _PlugInManager command then scroll down and click Paneling Tools
Perhaps the problem is that I’m on a newer version than you. I have my update frequency set to Service Release Candidate (under preferences → General):
-Kevin
I have modified the definition I posted above so it runs faster:
Engraved_Torus_004.gh (24.3 KB)
Rather than generating the whole object with Paneling Tools, it generates one segment and copies it with Polar Array
It also generates the torus and the pattern object so there is no internalized geometry.
I have the same version of the PanelingToolsScripts (installed from package manager) that you show above.
It’s the actual PanelingTools plugin that shows a newer version.
-Kevin
Still not working for me?
If you update to the Service Release Candidate I think it should work.
Instructions on how to update here:
-Kevin
I just noticed the last definition I uploaded wasn’t producing a closed brep after the join component:
Flattening the input to the join component produces a closed brep:
Updated file:
Engraved_Torus_004a.gh (23.5 KB)
-Kevin
