Hi
How to turn on before starting a command and then turn it off after completion?
Hi Leex
from this page:
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/history.htm#(null)
Command prefixes for turning history on and off
Type these shortcut symbols before a command name to enable/disable history recording
# (hash)
Enables history recording for the following command.
For example: #ArcBlend
% (percent)
Disables history recording for the following command.
For example: %ArcBlend
Thanks Willem!
With a single left click on the [Record History] pane you can temporarily toggle the current history setting just for the next command.
I think this is not so clear in the help.
