Enable and Disable Multiple Components with Button Toggle?
Hi, I have a a bunch of solid unions and region unions which take a lot to compute, and I would like them to be disable as I vary my definition, but just when I am happy with the result I want these to be computed.
It would be like controlling many data dams at once. Or maybe just disabling and enabling these components with a “on, off” button.
Any ideas? Thank you
You could use a Toggle to control the output index of a [Sift] or [Stream Gate] component. Then leave one output unconnected and feed the other into your expensive components.
Thanks David, will try this out!
Hi ShynnSup,
You might also be interested in trying Metahopper for this function.
There is a component in Metahopper called Group Toggle which is a very convenient way to enable/disable groups of components.
thanks that worked for me!
