Can I control Disable/Enable from a GH component?
I’d like to be able to control the Enable/Disable parameter of several GH components from some sort of selection component. A simple Boolean switch would work.
I’m guessing the only way this can happen is with some sort of user code routine - if that’s even possible.
I think metahopper has something for that:
Thanks Chris - installed it and it does what I need. There are probably some other things in there that I can use too.
