Disable/enable component based on boolean
Is there a possibility to turn on/off components based on a boolean?
Metahopper has a ‘Group Toggle’ which does this, but unfortunately I cant control this Toggle using a boolean. (You really have to ‘manually’ click on this toggle)
Any suggestions? (or workaround?
2021-11-21 Disable-Enable component based on boolean.gh (10.8 KB)
Thanks! :slight_smile:
Have you seen the Enable/Disable Object component?
Ahh perfect!
Thanks! :+1:
