I would like to know if visual arq can create elevations using elevation symbols. The forum currently only refers to elevations in regard to height datum symbols and opening elevations. In Australia we have a separate symbol for elevations which has no cut line like a section.
For now you will need to create those as 2D Rhino blocks and use VisualARQ sections to view the elevation, you can hide those section lines for example by placing them in a layer.
I haven’t got the dynamic text working yet or the background hatch of the circle. I was also thinking we could have the sections uses in the model as the menu options for the symbol text.
It would be good if the text height was linked to the radius of the elevation symbol.
Also, if the text would remain readable when rotated.elevation_symbol.gh (18.5 KB)
Hi Luke, thanks for sharing the definition. It looks great.
In VisualARQ 2.7 version the Annotation object will take a plane as insert point, so it will be possible to insert it in vertical CPlanes (that means in Front or Side viewports).
