Hi there,
I’m trying to edit the profile of a wall using the newly introduced API methods in Revit 2022 and I’m having a weird crash issue. Before I get to that, I know there’s a component for creating a wall by profile but that’s not what I want to do. I need to create the wall by curve and then edit its profile.
So at the moment I have the following code:
import clr
clr.AddReference('System.Core')
clr.AddReference('RhinoInside.Revit')
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
from System import Enum, Action
import Rhino
import RhinoInside
import Grasshopper
from RhinoInside.Revit import Revit, Convert
from Autodesk.Revit import DB
import RhinoInside.Revit.Convert.Geometry
clr.ImportExtensions(RhinoInside.Revit.Convert.Geometry)
#clr.ImportExtensions(Convert.Geometry)
doc = Revit.ActiveDBDocument
def EditWallProfile(doc, wall, profileSegments):
with DB.Transaction(doc, 'get the sketch') as t:
t.Start()
sketch = wall.CreateProfileSketch()
t.Commit()
skEditScope = DB.SketchEditScope(doc, "edit the wall profile")
skEditScope.Start(sketch.Id) #
with DB.Transaction(doc, 'delete the existing sketch and create new sketch') as t:
t.Start()
exElems = sketch.GetAllElements()
for elId in exElems:
el = doc.GetElement(elId)
print(el)
#if el is DB.ModelLine:
try:
doc.Delete(elId)
except:
continue
# create model lines
for item in profileSegments:
revitCurve = item.ToCurve()
print(revitCurve)
c = doc.Create.NewModelCurve(revitCurve, sketch.SketchPlane)
t.Commit()
# close the sketch editor
skEditScope.Commit(FailuresPreprocessor())
class FailuresPreprocessor(DB.IFailuresPreprocessor):
def PreprocessFailures(self, failuresAccessor):
return FailureProcessingResult.Continue
if Trigger:
wall is a wall create by location line.
and profileSegments is a list consisting of line-like curves that are in the same plane as the wall.
What happens in the first try is that sometimes I get a “managed exception by Revit or a third party” error (paraphrasing). If I re-trigger the python component it’ll run then it goes in sketch editing mode and shows my desired sketch in the sketch mode. However it won’t close the sketch mode. And when I click on the UI it closes the sketch mode without applying the new sketch. After a couple of tries then Revit crashes.
I’ve done the same thing through Revit’s Macro manager and it works fine so the code does not seem to be the problem.
My guess is Rhino Inside somehow is stopping Revit to come out of the sketch mode gracefully. And Revit doesn’t know how to handle it.
Any ideas how to fix this? Sample Rhino and gh files attached.
EditRevitWallProfile_.gh (9.3 KB)
EditRevitWallProfile_.3dm (25.0 KB)
