i have tried to bring in a wall that is defined by 2 slanted walls some how i was not able to edit the profile of the wall . please look at the attached image and let me know how you solved something similar. thanks
the green circles are the correct ones i edited after . the yellow is the profile i wanted , i already have the profile curves in rhino grasshopper but i don’t know how i can get them into revit.
Hi sofonias,
Can you post the curves and a small example of the revit as well? Thanks
thank you for the reply japhy,
i tried to bring in the wall slit windows with modified profiles but i dint find a way the one you see above is the walls i brought by isolating the to curve and using a z vector with height parameter. then i modified the profile in revit . but i hope ther is a better way to import this…
in rhino the ones in white are the windows
