Hi. I have a problem with edit the curve object as attached by using pointon. My rebuilt setting is Point degree 12,degree3. I wonder how to edit the curve with more point horizontally
Your Comment Is Highly Appreciated.
Is the object an “extrusion”? If so try using ConvertExtrusion on the object to convert it to a regular NURBS surface. Then use Rebuild.
