Hi, is there a way to fillet a curve in a more dynamic/realtime way?
As in specify the radius to mouse click as opposed to setting a preassigned value.
How revit does it for those who use it.
Thanks,
Adam
Thanks,
Adam
You may try the following script:
Fillet curve with preview (for some reason it does not work when using an arc and a straight line together):
FilletCrvTest.py (13.0 KB)
FilletCurves.rhp (21.5 KB)
Also, this script is good for adding fillets to surfaces:
Fillet surface corner:
FIlletSrfCorner.py (9.0 KB)
More useful scripts:
A simple tutorial how to use scripts:
