When inserting a set of cross-referenced DWGs, Rhino seems to get confused. For example, say you have a set of plans, ground floor and first floor. The ground floor contains an xref of the first floor, and visa vera.
It’s fine if only one drawing is inserted; the ground floor appears by itself. But if you then insert the first floor plan, both the first floor and the xrefed ground floor appear together. Presumably this has something to do with the referenced drawing already existing in someway in rhino.
This is true for current version of Rhino for Mac and Windows. And from my memory, it hasn’t always been the case. I’ve certainly setup files with DGNs from Microstation without having this issue.
It’s possible I’m overlooking a setting or something. Un-checking ‘Read linked blocks from this file’ makes no difference.
Hopefully someone can help. Thanks.
